Radia Circuit test | on ElectriciansForums
Discuss Radia Circuit test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
Nickyboy85
Heya peeps,
I got my Level 3 2330 Inspection and Testing practical coming up soon, and I'm a bit confused about Radial circuit testing. Looking at the booths, there's 3 radial circuits on one distribution board, each circuit having one socket. When I conduct my continuity test, can the polarity be tested at the same, like you do with a lighting circuit?
Sorry that's radial, bit eager there :rolleyes:
No problem with doing your polarity test with cpc tests as the method is the same. What you must do is mention that polarity has been confirmed otherwise your examiner might think you have forgotton it altogether.
Chris
Reply to Radia Circuit test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
