Radial circuit breaker | on ElectriciansForums
Discuss Radial circuit breaker in the Australia area at ElectriciansForums.net
C
cohen79
Hi everyone
Just a quick question.With the new regs,when installing a radial in 2.5mm cable the max CB to use must not exceed 20A.Will it be okay for me to install a 16A CB seeing that this is below the max permitted?
Thanks!
C
Thanks James
The cable is run in the ceiling but not underneath or through insulation.I've clipped it to the joists direct and the circuit only feeds one 2-gang 13A socket.
Thanks again.
Conrad
Reply to Radial circuit breaker in the Australia area at ElectriciansForums.net
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
