C
Carlos_tlewis
Hello,
I'm glad I've found this forum
I'm doing PIR for a customer and everything was going fine until I saw there was one 2.5mm cable leaving from consumer unit to feed 4 sockets.
The cable leaves the consumer unit and the passes threw a double pole isolator switch, it was wired this was so they could control effects lights.
At the consumer unit the radial is on a 20A MCB.
Now as the customer said there all LED lights or cameras that are plugged into the sockets so they don't require much at all.
Is there anyway this would ok? the customer asked me to check as he said when the electrician first wired it he was 'hot' on his regs. if not would it be best putting a code 2 down on cert?
Thanks,
Carl
Thanks,
Carl
