radial circuit | on ElectriciansForums
Discuss radial circuit in the DIY Electrical Advice area at ElectriciansForums.net
H
hullman4
i had a couple of sockets put in about 12 year a go and was thinking of adding another for tv on wall and was looking under floorboards and it looks like its done on a radial circuit as it come straight from the fuse box and ends at the 2nd socket ,it is also wired to the up stairs socket fuse when its down stairs is this ok
if it's a spur from the CU on a 30/32A fuse, then it's not compliant with regulations, as only 1 outlet should be fed as a spur unless fused down.
Reply to radial circuit in the DIY Electrical Advice area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
