SW1970
Hi, newbie here. Friend has asked for opinion on quote from another sparky. Single radial to conservatory replacement. Proposal is 6mm2 feed for 4 socket outlets and 6 lighting points back to CU. No mention of RCD or fused units in conservatory. Cable run 20m, floor area 25m2.
I think solution should be separate feeds of 2.5mm2 and 1.5mm2 back to RCD protected MCBs of 20A and 6A. Cable run is straightforward.
Can you guide on whether sparks approach is ok (in particular it all being on one circuit) and if mine is more appropriate?
Many thanks
SW.
Many thanks
SW.
