Radiator flex pipes plumbing advice | on ElectriciansForums
Guest viewing is limited
  • Thread starter Glasgowman
  • Start date
  • Replies 0
  • Views 87
Discuss Radiator flex pipes plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Radiator flex pipes Could I pull these flex pipes up by cable tying them onto the back of the radiator (it’s a double rad) Just wondering if the heat against the cable ties would be ok. I’ve seen the cable clips you can get but not much room for them. Any help appreciated
Radiator flex pipes to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Radiator flex pipes plumbing advice in the Plumbers Forums area at ElectriciansForums.net
B
Draining radiator? I’ve got this radiator that I need to drain down & remove to clean out due to sludge. Can I drain it with that drain valve on...
ben100
B
R
Radiator size Hi. Currently have 3 small double radiators (500x600) in our open plan living room/kitchen diner. Would like to change them for...
robcharlton
R
Recommended Sponsor News
Hi everyone,
Email
Time zone
Last seen
Plumbers Forums
Thread Tags
Tags
None
