Radiator valves question plumbing advice | on ElectriciansForums
Discuss Radiator valves question plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Radiator valves question Hi guys, got supplied some corner valves but they have a rubber to go into the radiator inlet to create a seal.
Well I imagine that's the idea, fit hundreds of valves but always used Ptfe or Loctite. Never actually seen one like this.
Will the rubber do the job, or should I remove and fit as normal with Loctite?
Any advice be appreciated
Radiator valves question to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Radiator valves question plumbing advice in the Plumbers Forums area at ElectriciansForums.net
B
Draining radiator? I’ve got this radiator that I need to drain down & remove to clean out due to sludge. Can I drain it with that drain valve on...
ben100
B
What valve is the flow Hi all I removed a radiator off the wall and forgot to note what valve was the flow as I'll be replacing with a new...
dwalsh1
