Radio interference from downlights | on ElectriciansForums
Discuss Radio interference from downlights in the Australia area at ElectriciansForums.net
Richard Burns
Mentor
Cambridgeshire
I have just had a customer who is getting radio interference (not sure if this is new or has been going on all the time)when one set of downlights in the Kitchen is turned on.
This is four 50W 12V downlights, they are wired with two 105W transformers in a kitchen cupboard each transformer supplying two downlights wired in flex.
I am initially assuming that because the flex run is over 2M this is the "antenna" causing the interference.
However if this is a new occurrence it may be the Tx breaking down.
If I replace the txs would this have no effect (or make things worse)?
would the better solution be to supply each downlight with its own local tx, utilising the existing flex reconnected to 230V, access a bit difficult but should be OK.
Am I barking up the wrong tree entirely?
Is the radio interference on AM, FM or digital?
We get interference on our digital radio in the kitchen and its related to the boiler and whether or not the kettle is switched on at the plug!
It's most likely one or both of the transformers, especially if their the electronic type. I don't see that the flex length on the ELV side would make a difference.
Is there a dimmer involved in this equation? if so is it leading or trailing edge or phase angle? Those are the usual suspects when it comes to RFI.
At the time two of the lamps (on one tx were not working and so when this one connected no problem (but no current flow) the other one did cause the interference. switch off no buzzing, switch on buzzing (on the radio)
No dimmer but it is a 3 gang switch.
Not sure which channel radio was tuned to, but sounded pretty generic static.
well, in cambridgeshire, you can't reeieve rock radio from manchester, so, as every other station is pants, radio is redundant down there. has nobody mentioned to the cambridgeshire inhabitants that we now have a new medium, it's called television. it's a sort of wireless with pictures, invented by a scotsman.
Is that on my am band, I don't think my valves are glowing enough to receive that!
depending how easy it is swap the tranny's and see if the fault follows,you can get some strange frequencies with faulty lighting..
I think I will swap out the Txs for new ones, replace the broken lamps and see if the problem recurs, failing that I will change the txs to wire wound for the whole block.
Not sure the customer would want GU10s as the rest are all MR11 (about 30 of them!), I could change them all but a bit costly.
Reply to Radio interference from downlights in the Australia area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
