range cooker fault | on ElectriciansForums
Discuss range cooker fault in the UK Electrical Forum area at ElectriciansForums.net
Look for the model number online and see if you can google a circuit diagram. Should give you an idea of what stats are in the circuit. Sounds like an "over-temp" stat to me (rather than the temp control) as it has to cooldown before remaking.
Reply to range cooker fault in the UK Electrical Forum area at ElectriciansForums.net
I recall where a fluorescent capacitor would cause a separate socket RCD to trip when turning off the light
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
