rate my fuse box (or consumer unit to be politically correct!) | Page 2 | on ElectriciansForums
Discuss rate my fuse box (or consumer unit to be politically correct!) in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
Job done today. What do you think? I thought it was quite sexy! :eek:
  • [ElectriciansForums.net] rate my fuse box (or consumer unit to be politically correct!)
The original fuseboards were in the cupboard beside the meter as in the picture. The cables ran behind the bit above which was already boxed in with plywood. All I did was move the new consumer unit up and replaced the plywood. I upgraded the tails to 25mm and took them up to the new position. Do you think I should have an upfront 100mA rcd?
Do you think you should have one ?
Not for additional protection, but i am sure you already knew that.
No point fitting a 100mA RCD - it wouldn't comply, as it needs to be 30mA for shock protection.
I like your approach, looks neat, but as I said, you could come unstuck if you put it up for assessment.
Personally, I would consider it to be no different to running the tails in trunking, but that's just my opinion. Yours is wider, and made of plywood, but it's doing the same job. ;)
What if the meter tails are more than 50mm from the surface? I did a job once, where I ran the meter tails surface in maxi trunking, in the corner of a wall below the CU. Went back a few months later and the customer had boxed in the trunking!
I'm not a fan of that warning label taped above the CU; technically it's a safe zone anyway, you could have made the sign more discreet and fixed it better.
What does that switch do? I'd have probably labelled that instead.
Reply to rate my fuse box (or consumer unit to be politically correct!) in the UK Electrical Forum area at ElectriciansForums.net
There's a difference between being required to install an RCD and being required to have a full rewire when all the houses around have similar...
  • Duplicate posts
    Any suggestions for avoiding the duplicate posts that keep happening? I'm trying to delete mine...
  • Duplicate posts
  • Borrowed earth
    I don't think Westward is suggesting the existing cpc is 4mm. He is saying the new earth pinched...
