rate my fuse box (or consumer unit to be politically correct!) | Page 3 | on ElectriciansForums
Discuss rate my fuse box (or consumer unit to be politically correct!) in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
Job done today. What do you think? I thought it was quite sexy! :eek:
  • [ElectriciansForums.net] rate my fuse box (or consumer unit to be politically correct!)
Looks neat enough but as you're asking for opinions/options, I would have built an extension on top of the existing cupboard using stud and plasterboard and then clipped all cable to the block wall - this would have made them all more than adequately protected depth wise and then mounted recessed consumer unit in the stud wall extension. Just another option obviously but as said this looks fine anyway.
One thing I would suggest is that the ply above the CU is cut and screwed so that it can be removed as an access trap,obviously that would mean locating the switch elsewhere. It makes it a doddle to get additional circuits into the CU in future...as you have installed it'll be a pig. Otherwise nice tidy job!......(what does the small green earth in with the main earth/bonding go to?)
Remove the cable ties from that bundle of neutrals and in future use something other than a machete to remove the sheath from the tails. Actually not bad at all.
Slightly tongue in cheek, as it's a decent job. OTOH if you present tidy work and ask for critique, it will be judged to very high standards. I'm not looking for gross errors and don't expect there are any, I'm looking for finesse. I'd have used a Rotax stripper and the sheath would be very neat indeed.
Yep,i would concur...i have an old Thomas Betts sheath scoring device,which works both peripherally and longitudinally (not bad for a Sunday night...)
I am always surprised when sparks with plenty of years under their belt,say "Ooo,that's a handy tool..."
Reply to rate my fuse box (or consumer unit to be politically correct!) in the UK Electrical Forum area at ElectriciansForums.net
There's a difference between being required to install an RCD and being required to have a full rewire when all the houses around have similar...
  • Duplicate posts
    Any suggestions for avoiding the duplicate posts that keep happening? I'm trying to delete mine...
  • Duplicate posts
  • Borrowed earth
    I don't think Westward is suggesting the existing cpc is 4mm. He is saying the new earth pinched...
