B
bearlyable
Howdi
I have a 32a ring that when I test the RCBO it won't achieve 40ms when tested at 5x in 0 degrees but when switched to 180 degrees it trips well within 40ms The Zs measured is 0.49 ohms the circuit trips at 1x okay so Im a little confused and am looking for help to point me in the right direction so as to avoid pulling everything apart so any help is most welcome. thank in advance ps I have swapped the RCBO
