RCBO/CU Problem | on ElectriciansForums
Discuss RCBO/CU Problem in the Australia area at ElectriciansForums.net
SSE
Went to change mcbs to rcbo's in a wylex board that's used for total control heating. Then I hit a problem as some off the rcbo's don't fit as the neutral bar is in the way! Instead of the main neutral feed to the bar being cable it was one of those copper pre made ones so can't move it up. What's my best bet to solve this problem?!
forgive me on this one, but isn't there are reg in the BRB which states that in order to comply, equipment must be used and installed in accordance with manufacturers instructions, and generally in these instructions it states that only genuine equipment which is compatible may be used?
so chopping and changing of manufacturers RCBO's in to another manufacturers CU wouldn't be allowed?
Probably making a right clown of myself here, but thought I'd better ask!
That's a very good point, although I don't remember seeing anything stating this in any CU manufacturers literature, it may be there I guess. I'm not sure that they can reasonably say only their product can be used, as most CUs by definition are adaptable, but who knows.
im sorry mr MK i want a refund as the box i fitted your RCBO in was a wylex and the common din rail caused problems!! dont wash with me! load of bull to be honest! bit like fitting a set of ford wheels on a renault!!! as long as you have not had to adapt the bloody thing to fit it will be ok!
how many of you have left the surface mounted back box of a MK shower pull cord and just replaced a new front with a Niglon or Polar pull cord and discarded the back box from new unit!
Reply to RCBO/CU Problem in the Australia area at ElectriciansForums.net
