Rcbo problem | on ElectriciansForums
Discuss Rcbo problem in the Australia area at ElectriciansForums.net
E
ElAl
I have just fitted a new D/B with all RCBOS there were 3 rings 1 to a cylinder and a few lighting.
All tested well apart from last ring which has no continuity on the neutral but when I pull 1 leg of the neutral out (to find Break) my polarity checker gives me an earth/live reverse fault.
When I put back the leg it returns to normal!
The only thing I can think of is I have the wrong leg connected hence no continuity but why is there a L/E reversal?
Any ideas?
Al
Any ideas?
Al
Never trust a martindale, if thats what your using. Majority don`t dettect n/e reverse. It sounds like this is the problem just no neutral at outlet
Reply to Rcbo problem in the Australia area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
