RCBO Question | on ElectriciansForums
Discuss RCBO Question in the UK Electrical Forum area at ElectriciansForums.net
SKY
A simple one I guess but one I have not come across:
3 bed house - 1 CU - 16th edition I guess with 1 RCD covering 5 circuits.
The kitchen was on the downstairs ring.
I have added a brand new kitchen ring and a 6mm cooker feed.
Can I use RCBOs to protect the circuits on the spare side that is currently unprotected by the rcd?
Thanks All
Yes but you only need to on the circuits you have installed or extended. Depending on the board RCBOs can be a very tight fit due to the height and can be very tight against the earth and neutral bars making a tidy job almost impossible.
Thanks All
If you have calculated your maximum demand and the installation allows then the suggestion you put forward is the most desirable in my opinion.
You may or may not be aware that the work you mention is covered under Part P of the Building Regulations therefore it will need signing off appropriately.
Only once have I struggled with Wylex RCBO's and that's only because the installer before had thrown in the cables and left very little room. after a few alterations they slotted in just fine and the new cables terminated perfectly.
:thumbsup
Reply to RCBO Question in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
