RCBO required on an already RCD'd board?? | on ElectriciansForums
Discuss RCBO required on an already RCD'd board?? in the UK Electrical Forum area at ElectriciansForums.net
Diode
Hi, if I'm using a 17th edition Cu including RCD's, do I need to fit an RCBO for shower circuit? Or simply an MCB?
You should never fit two devices in series that have the same tripping characteristics. Be them Rcd's or CBs
(Or other forms of OCPD alternative to CBS)
This is to prevent two devices operating in the event of a fault, it should be the nearest device to the fault that operates first.
Hope this makes sense.
I thought it was overkill and wondered what u guys thought. Thanks
Hi
Hard
to comment as cannot see your exact situ, but if you mean placing a 30mA RCBO in series with the existing RCD in your dual RCD board, then yes, it is overkill. And also a bad idea as you have two RCD devices in series with no discrimination.
- - - Updated - - -
Hi
Hard
Reply to RCBO required on an already RCD'd board?? in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
Ye smaller board (containing the RCBO'S) will literally be next to the MEMSHIELD, And hence the 32A MCB be simply feeding power to a 32A RCBO I...
