RCBO 'stuttered' tripping when test button is pressed | on ElectriciansForums
Discuss RCBO 'stuttered' tripping when test button is pressed in the UK Electrical Forum area at ElectriciansForums.net
England
Just wondering what this might be.
It was a brand new Schneider RCBO fit into an older Square D board. RCBO fit on the non RCD side. Everything working fine, load is on and pulling. I always press the test buttons on the RCBO's just to check, and this time the switch 'stuttered', sort of fluttered a bit before it went off. Subsequent trip button tests tripped it instantly. I then tried again 5 minutes later and same thing - first attempt was a fluttering, stuttered successful trip, second, third, fourth etc times all went straight away.
Anything to be concerned about? Googled but couldn't find any answers.
Pressing the test button and checking its function is a requirement, there's a box to tick on the schedule of test results for that very purpose sonits good you "always do it, just to check".
Did you manage to do any other testing before your tester packed up or was it a case of switching on and hoping for the best?
Not all the square d boards....still a problem with some of them
Any Schneider breaker with iKQE on it is Square D compatible. Many others are too.
Reply to RCBO 'stuttered' tripping when test button is pressed in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
