M
madrid
had a job today ,fitted a new board including 5 rcbo's.newlec own brand which is wylex.All rcbo's tested fine apart from the ring circuit 32 amp one.Tripped within the time on 1xIn on both occasions tripped at a time greater than 40ms and then would not trip on the final test.changed the rcbo for a new one still got same result.Anybody got any idea what could be causing this.I did a pir first so all readings ok.loop impedance fine ,ring continuity fine.
