RCBO trip test query - Testing wrong or is there a fault? | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss RCBO trip test query - Testing wrong or is there a fault? in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Hamilton
Hi,
Can anyone please explain why my friend's 30mA trip RCBOs passes the trip test (e.g. x5 is less than 40ms) when the test is done at the consumer unit but fails when the test is done at the sockets.
Is he doing something wrong or is there a fault somewhere (the RCBO or the circuit?
Thanking you in anticipation.
I beleave its the way the tester works to simulate the fault , if there is already leakage on the circuit, for example a fridge or computers , thats when the tester gives the false readings .
I would suggest ramp testing the RCD
Had this problem a little while ago fitted a new consumer unit and everything tested ok, went back 6 months later to do some additional work and the RCD would not trip on the 1x test and the 5x result was a bit close to the limit when tested at a socket same tests at the CU gave satisfactory results although I was not too happy so decided to ramp test at the CU and the socket and both results were very similar with an indicated trip current of 35ma. The result after a phone call to the manufacturer was a replacement RCD in the post
I now always ramp test RCD's before any other tests and I have had quite a few that trip above the rated tripping current
Reply to RCBO trip test query - Testing wrong or is there a fault? in the Electricians Jobs area at ElectriciansForums.net
Long shot, but looking at the previous posts. hope i have understood correctly. 1. continuity between live and earth 2. no continuity between...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
