anyone got any ideas on this.
Had to change a lighting circuit mcb to an rcbo due to cable we put into the wall (work is on a school). The old mcb was 15amp rated and 1.5mm twin and earth circuit. I changed the mcb to a 10amp RCBO but when I tried to turn on it tripped. so I thought it could of been tripping due to overloaded, I then changed the RCBO to a 10amp MCB and it was fine so no overloading. I then went around disconnecting the outside emergancy lights and trying to reset the RCBO. Got the first one on with the rest disconnected but when it came to the secound light it tripped. Byepassed the second onto the third and still tripped, then I disconnected the first light byepassing it and put the secound one on with the rest off it stayed in. Its like everytime a light is added it trips as if overloaded. the RCBO was type C as well any thoughts on this.
thanks
thanks
