rcbo tripping. | on ElectriciansForums
Discuss rcbo tripping. in the Australia area at ElectriciansForums.net
first rcbo is in the board the second is in a seperate square D enclosure in a bedroom. the enclosure and rcbos were the materials ordered for the job. thinking to swap the rcbo at main board for a 6 a mcb see if that cures the tripping
You said you where altering wiring, then you say no wiring has been altered there is no need for 2 rcbo's in series so why it's there I dnt knw. If the first RCD is tripping out it there will be a fault beyond that!
Reply to rcbo tripping. in the Australia area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
