rcbo's for comercial kitchen | on ElectriciansForums
Discuss rcbo's for comercial kitchen in the Electrician Talk | All Countries area at ElectriciansForums.net
solo2771
Hi while working in a local restaraunt i noticed there is no rcbo's or rcd's protecting the kitchen.
am i right in thinking all circuits in the kitchen and cold store should be rcbo protected?
also toilet hand driers, sockets in the bar and also outside water feature.
varied old and not so old.
Hi,
if you are doing any alterations or additions it is quite likely that you will be issueing an EIC or a MWC, and "the contractor shall record any defects found in the existing installation"
and all your aforementioned rcd absenses sound like worth bringing to the owners attention,and I
think I would suggest to the customer that he gets a periodic inspection report carried out to identify possable defects and departures from regulations that may give rise to danger to the public,his staff or maintenance personell such as yourself.
Reply to rcbo's for comercial kitchen in the Electrician Talk | All Countries area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Im not as clever as you guys. I would be doing what somw others have said, I would be leaving certain items switched off for a period of time...
All socket outlets up to and including 32A (which are commercial, not domestic) are required to be 30mA RCD protected. By the sounds of it you...
