RCBO's or 2 RCD's | on ElectriciansForums
Discuss RCBO's or 2 RCD's in the Australia area at ElectriciansForums.net
E
eagleeye
Hi Guys i am doing a job with a TT supply system would like your suggestions on weather to fit 30mA RCBO's on each final circuit or just a dual rcd split load CCU. I thought seperate RCBO's as the guy wants mains voltage downlights and we all know how many times it knocks the rcd out when they blow and also as i think that its better than a row of circuits trip off when only say a bulb blows. allbeit that itsgonna cost more money than the 17th edition dual split load
Reply to RCBO's or 2 RCD's in the Australia area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
