RCBOs vs RCDs with MCBs | on ElectriciansForums
Discuss RCBOs vs RCDs with MCBs in the UK Electrical Forum area at ElectriciansForums.net
In a domestic set up ie average (if there is one) house is there any reason you wouldn't use a RCBO but a MCB and a RCD?
I can't think one
Fred
Cost. Also the RCCB will switch the neutral pole whereas the RCBO may well be single pole and leave a neutral/earth fault in situ. Not good if there is an upstream RCD.
Did you mean 'not good if there is not an upstream RCD ' ?
If there is an upstream RCD then that will clear the fault and the SP RCBO will not be so much of a problem.
Think I know what OP means....I think RCBO's is the way forward nower days as the cost of RCBO's is now far cheaper than it used to be, making more viable for the general public to afford. You can get DP RCBO's which under fault conditions will open both poles.
I can't think one
Fred
RCBOs single and not double pole (majority)
RCBOs expensive compaired to a split dual RCD board fully loaded
RCBOs take too much room up in average domestic boards, not curves though
RCBOs have horrible white fly leads which look like a ball of wall in the boards and make the boards harder to look neat
RCBOs have horrible long neutral leads which look like a ball of wall in the boards and make the boards harder to look neat.
RCBOs are better for individual circuits rather than an RCD covering 5 breakers in a split due to nusience tripping
How many more examples would you like?
RCBO's a far better way to go with an older installation and/or a poorly extended property!
Are you a fan of RCBO's? lol
Reply to RCBOs vs RCDs with MCBs in the UK Electrical Forum area at ElectriciansForums.net
The legs on the bus bar are too long for the new rcbos
Thanks Westward, and that last paragraph with the Note about no characteristic marking is exactly what I needed to see.
