La Poste
This might sound like an obvious question but do rccd's have overcurrent protection?
When you buy a 17th edition board that has two double pole RCCD's one at 63A and one at 80A are these RCCD's effective for overcurrent as well as earth fault leakage?
I have been looking at double pole RCBO's that act as MCB's and RCD's combined and can be chosen in many different sizes from 6A upwards.
The RCCD's in a 17th edition board are designed to be used with MCB's so that one RCCD will supply an array on MCB's and the MCB's will act as overcurrent protection.
But why is the RCCD rated at 63A? Does this mean that it will also act as an overcurrent device if the current should exceed 63A.
Can these RCCD's be used both as overcurrent protection devices and as RCD's?
Cheers.
Cheers.
