RCD Fail, or Not? | on ElectriciansForums
Discuss RCD Fail, or Not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Cornwall
Folks,
New shed CU, 16A & 6A MCBs with integral 30mA RCD main switch. RCD test at 1x is >400ms tho' 180 degree test ok at 18.6ms. That's a fail though yes? Max measured time being >400 ms.
Just asking....don't get RCD fails often. :confused:
Cheers!
No neutral - earth faults? They give you false results !
Sticky RCD's are common too. Test once, fail. Try them again and they pass ! So much for the three monthly testing.....
Reply to RCD Fail, or Not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
