dolomite
Hi everyone!!
Your thoughts on an issue I've come accross today please!!
MK consumer unit, split with RCD covering cct's 8-12. 32a MCB Put in a new cooker cct today in no9, 6mm T&E, single DP switch and a connector for the cooker. Cable run is about 10m's total.
R1+R2 ok, polarity ok IR's all over 299Mohms (Megger 1553 MFT).
All good so far.
No Trip earth loop test, the RCD trips. Same with PFC. Tried it a few times to make sure I've got the right leads in right places and they're connecting well, but it keeps triping.
I did a PIR there last week and checked the RCD then, all ok. Checked, checked and re-checked, always the same!!
Now I've connected the oven back in and as soon as the cct is live it trips. But connect into sockets, no problem!!
I'm left scratchin my head on this one. Any idea's? Am I missing something?
Got a new RCD to fit tomorrow to see if that makes any difference. Fingers crossed!!
Might be worth saying that the CU was fitted by someone a couple of years ago, but they left in a hurry never to be seen again. No excuse on my shiney new cct tho!!
Thanks all
Dolomite
All good so far.
Thanks all
Dolomite
