RCD FCU in bathroom | on ElectriciansForums
Discuss RCD FCU in bathroom in the UK Electrical Forum area at ElectriciansForums.net
B
bonn1ett
Hi,
i have been asked to install a towel rail in bathroom. Looks like there was already a towel rail there before as there is a blanking plate low level which has a feed in it from a fcu outside the bathroom. There is no RCD protection on the circuit (old fuse board).
I was thinking of removing the blanking plate in the bathroom and installing an RCD fused connection unit to supply the towel rail? Or should the RCD fcu replace the switched fcu outside the bathroom and a blanking plate with cable outlet used in the bathroom?
any thoughts?
ta
I would RCD the circuit at its origin. If it outside the zones, then it would be acceptable to use an RCD FCU, but not ideal. But then again, some people have normal light switches in bathrooms, so the same would apply to this as well.
Cheers...........Howard
Easy way out would be to replace the FCU outside the bathroom with a RCD FCU. Some here say its doesn't comply with regs but some would argue it would. Ideally you'd place the RCD at the "source" of the circuit but often this isn't feasible or financially viable with the client.
I don't think the customer would be willing to pay the extra for RCD installation at source although i will strongly recommend it! Was thinking to put the RCD fcu outside in place of the switched fuse spur as suggested but if i do and just put a blanking plate with cable outlet next to the rad how will they switch the towel rad on/off? I know they could use the RCD unit but thats not ideal is it?
Reply to RCD FCU in bathroom in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
