G
Gixxerdan
I have just recently bought a house which i am currently doing up. the consumer unit is a split load type with 1 rcd feeding the upstairs and downstairs sockets. I noticed that they have used the old cooker 6mm cable to feed the shed outside (t+e!) which I know needs changing to armoured and I think there should be rcd protection for it too as it is outdoors but what size rcd do i need? All there is is 2/3 sockets and two fluro fittings. Do i need a 100A 30mA rcd or would something smaller like a 63A 30mA do the trick? There is currently a chest freezer and fridge in there and the sockets will probably only be used for a lawnmower and strimmer. Also is armoured cable required or is 3 core sy substantial enough?
