sako
Hi all,what RCD should be used in a stable.Currently theres an DP isolator switch but my spark says this needs replacing with a 30mA RCD is this correct?
TIA
don't take much to drop a nag. RCD deffo.
Yep take the Advice of your Electrician and get him to test it all out afterwards.....Which he should do anyway
Section 705...Agricultural applies.
705.411.1...sockets not exceeding 32a require a 30ma rcd....all other final circuits rcd not exceeding 300ma.
Im no spark so assumming 30mA is less than 300mA?
Yes...the socket MUST be on a 30ma RCD....the lights can be on a 300ma RCD....but TBH I would prefer to put all the circuits in a stables on 30ma RCD's. If you install a 30ma RCD main switch and that trips you will lose all power,although there are only two circuits,it may be better to leave the DP main switch and install a separate 30ma RCBO for each circuit.
and watch how and where you bury the cable. should i shout it out, nay, i'll go hoarse
I was told that the horse has a lower dangerous voltage threshold, maybe as low as 25V.
Is it the metal horse shoes?
The front to back legs can't be much wider apart than a bull/cow.
Can anybody confirm this and is it stated anywhere?
If so is a 10mA RCD safer?
RCD for Stables
sako,
armbands0,
