Going to install some decking lights. The fuse board is old school re-wireable fuses - no RCD protection. The owner doesn't want a consumer unit change (yet).
My plan is install an RCD protected fused spur from the kitchen ring main.
The ring itself won't be RCD protected but the spur feeding the garden lights will be - is this acceptable according to 17th edition?
The only other alternative I can see is RCD protected garage unit next to the existing fuse box - putting the old ring main onto that and then spurring off that into the garden - expensive and fiddly though.
Input appreciated.
Input appreciated.
