Rcd head scratcher | on ElectriciansForums
Discuss Rcd head scratcher in the UK Electrical Forum area at ElectriciansForums.net
Welchyboy1
Nearly Esteemed
Essex
Farm job im at has a problem
three phase tt system comes into main barn area, three phase main distribution board (with 100mA s type 4 pole rcd as main switch) supplying barns and general farm buildings
Swa single phase supply to farm house(around 40meters away), supplied directly from meter side of distribution board on henly blocks to switchfuse/rcd
so house supply is totally independent from the barn supply
however everytime there is a fault on the barn distribution board and its main rcd operates it takes out the rcd at the farm house too
i havent been over to the farmhouse yet but i cant understand why it would be knocking out the rcd in the house?
any ideas?
Where abouts is the suppliers transformer ...is it close up a pole?
What kind of rcd's are they - are they modern type that measure inbalance between L/N?
Have you ensured all your customer side connections are sound and tight... check busbar tabs are on the correct side of any mcb, rcd and main switch terminal clamps.
If theres a single earth stake in use for both barn and house , and all bonding is done at the house , it could be the Ze of the earth stake is higher resistance than the bonding at the house and fault currents are back fed to house , just a thought,,
This reads plain to me but a few are not reading the OP properly ...
At mains there is a 3ph board with 100mA rcd main switch
Also a 1 phase supply straight of the meter via a henley block to a sw/f + RCD ...lets assume 100mA
When a fault trips the rcd of the 3ph board the rcd IN THE house trips so assuming a 30mA is tripping in the house possibly 17th edition board.... can the OP confirm this!?
Edit confirmed in post 15.
Reply to Rcd head scratcher in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
