I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit type A in the future, but if following what is says in wiring matters should have type F for my inverter drive washing machine, as if that will ever happen.
However two point with the solar install. One was the UPS system, to allow freezers and central heating to run when we have a power cut, earth rod fitted and the 4 sockets for freezers RCD protected, great not problem there, but the central heating has no RCD protection any more, not on a plug so maybe not required? But it is one item which is worked on live by plumbers, so would have expected RCD protection.
Second is the iboost+ it seems DC is fed to the immersion heater, is this a problem with a circuit protected with a type AC RCBO? I really don't know, can the DC get on the supply, or is it like the washing machine, and no one worries about the DC?
