T
TPES
Hi All
Ive had a problem as the tittle says.
I have done a mains change from a very old Wylex board (4 way) to a 10 way hager board.
When i'd completed the change i had no problems at all.
8 hrs later i'd had a call from the customer saying all his electric had gone out!!
I got round to the customers house within 30mins.
The fault was as i had assumed the ring main was tripping the RCD. Its an old house with only 1 ring covering the whole house. Instantly as you flick up the breaker the rcd trips straight away.
The house has NOT been tested as of yet.
The customer had not switched any appliance on to cause the trip.
I had unpluged every appliance in the house and tried the RCD again..Nothing!
The board had been on and working fine for 8hrs no problem.
There was continuity through live, netural and earth.
To give the customer power again for tonight i had to put the ring onto the main switch side.
Im guessing there is some fault with the wiring of the ring main that only the RCD would pick up on and trip.
Is there any common cause for this? something i could check before removing every socket in the house?
Help appreciated.
Help appreciated.
