rcd not triping | on ElectriciansForums
Discuss rcd not triping in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
F
frenchy
hi could someone please help while doing rcd test my megger does frist test and on second test i keep getting a reading of >4000ms not shore how to sort it all advice appresiated:confused::confused:
no it doent trip at all had thie problem be fore upped the main earth this sorted out the problem getting the same thing happening not shore if its my testers or not
it's either tester, you, or the RCD. test an different RCD if that is OK< it means your tester and your method is ok. i would suspect the rcd. does it trip on the test button? rcd should trip even if the main earth is poor. look at TT system with Ze up to 200ohms or more.
Reply to rcd not triping in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
Sounds like it didnt live up to its IP65 rating. If under warranty get Amazon to replace it.
