RCD on bathroom LED mirror. | on ElectriciansForums
Discuss RCD on bathroom LED mirror. in the UK Electrical Forum area at ElectriciansForums.net
T
tosh-27
Hi folks,
hope everyone is ok.
We recently had our bathroom done and the electrician fitted and wired in our LED bathroom mirror.
He T'd off the lighting circuit in the loft and added a 5A fused spur as a 'do for now' but said we should buy a 30mA RCD to fit onto the fused spur back box. He said he left it for me to fit but now that i have the RCD won't reset at all.
I've double checked that it's definitely wired the correct way round but kind of thought if it was wired in reverse it would have melted by now.
Any suggestions why the RCD won't reset please.
Many Thanks
tosh
not possible to diagnose fault on tinternet. you need a local electrician. call him back, maybe. then again if he left you to do half the work, maybe not him.
Your electrician never should have said for you to fit it he is trained you are not. You are lucky you didn't get hurt.
Its seems like you have a fault on one of the circuits that is covered by the RCD, this isn't a fault you can find as you need test equipment. You are best off getting the electrician to come back check the RCD is fitted correctly and get him to trace the fault.
LED = Electronics = back voltage = RCD Trip. I'll bet the LED driver uses the earth as a ground and dumps the unnecessary voltage onto it thus causing an apparent "earth fault" resulting in the inability to reset the RCD. Damn this is so common it hurts!
Maybe a whole house worths will (I know it will, have seen it!) but not just one poxy mirror. If you've got +25mA coming from something only 3 or 4 watts to start with, I'd be ripping it off the wall as faulty.
Ring this so called Electrician up and tell him you have spoke to the local council and they have said that he should have wired the mirror to the 17th bs7671 standards, he should also have issued you with a certificate for the work done and ask him to provide one as the council wish to see a copy, under no circumstances should a competent Electrician be passing on part of the work to his customer if they are not competent themselves.... it could be argued he can to some extent but he would be obliged to return inspect the work and certify it.
The minute he suspects you have contacted other bodies regarding his work i can see him either doing his best to worm his way out of it or rushing back and doing the necessary .... makes me wonder if he actually fitted an RCD himself and couldn't clear the fault so rather than do the right thing he passed the buck to you.
That depends on the quality of the Tx used to reduce the voltage to that required by the LED. I have encountered some really rubbish ones that dumped the excess voltage from the electronic straight on to the chassis of the electronics, which is connected the EARTH and not the Neutral, thus more than 200V potential was being put onto the earth...that will Trip an RCD instantly..bearing in mind it only has to exceed 50Vac to do this....and if this is a DC sensing Unit then it will trip at very low DC levels too...
Like I said - if they're that rubbish I'd be ripping them off the wall!!
Really appreciate all of your input folks, many thanks. Certainly has now got me thinking, more about the credentials of the electrician rather than i have an issue with something i did.
I had him recommended to me as well.
Think i'll be calling him and getting him back. Although now i'm worried about what he really does know and is capable of doing.
Many thanks again for all of your input.
well, from what you've describved i'm imagining your've only got two cables in the switch?? I can;t see how he would go far wrong TBH! I'm sure theres someone on the forum who's nearby who would be happy to help if your not confident in your current electrician.
Reply to RCD on bathroom LED mirror. in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
I fitted a Mem MR30 Pod and MCB, about £75 for both.
