rcd or not rcd | on ElectriciansForums
Discuss rcd or not rcd in the UK Electrical Forum area at ElectriciansForums.net
B
brf
Hi all,
I am shortly going to be fitting a high integrity distribution board to a property which has two supplies (peak and off peak) fed from the meter outside the garage.the two supplies go into the garage into two 63amp switch/fuse disconnectors the main distribution board is then fed underground in mi cable. (The garage is not attatched to the house) question is,
Do I need to use rcd protection at the head to protect the supply cable or is the switch /fuse enough as I will have all circuits protected internally?
I hope that MICC cable is PVC covered and run in a suitable protective duct!!
I don't know why they call those CU's ''High Integrity'' they are anything but!! The only high integrity CU that i know of, is an all RCBO CU....
Reply to rcd or not rcd in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
