rcd or not to rcd, that is the question | on ElectriciansForums
Discuss rcd or not to rcd, that is the question in the Australia area at ElectriciansForums.net
Just a very quick one,
New Cooker Circuit, rcd or not,
Alteration to Cooker Circuit, rcd or not
Please quote regulation.
With the lack of information given it is impossible to reach any kind of informed conclusion.
As a spark, surely you know the reasons why an RCD might be required just as well as the rest of us??
HI TQ thanks for the reply, I would like to point out before continuing that I always make a point of protecting them, however I have recently been to installs where they are not protected and Ive been trying to find out weather this is a requirement or not. And having my head in the bgb and brb for a while, I keep coming back to regulation 411.3.3 which talks about sockets, however as you know not all cooker circuits consist of a socket. so please can someone give me a difinitave reply with the correect regulation as I am greatly interested in the response.
see reg. 522.6.6 and 522.6.7
Sorry I should have made it clearer,
the reference was taken from the BRB
Not many cables in a domestic setting are suitably mechanically protected, and even fewer at a depth greater than 50mm, so to all intents and purposes require 30mA RCD protection since the 17th Ed.
Edit: I do have the BGB, but have not finished looking through it all yet.
[/QUOTE]Not many cables in a domestic setting are suitably mechanically protected, and even fewer at a depth greater than 50mm, so to all intents and purposes require 30mA RCD protection since the 17th Ed.[/QUOTE]
Yea and thats what was blowing my mind, however some people just want to do the minimum to satisfy regulations, I havew been going to carry out some PIRs for this one letting agent in particular, and majority of properties are getting the same problem, currently I'm putting a code 3 against them all, it seems like the same 'electrician' has been doing installs for these guys. When Ive asked for previous records all i get are periodics, yet most of the cooker circuits are not more than 3 years old, all new colours, even new split board cu's etc.
Thats the reason I decided to look through regs, and also post here. To see if there was a definitive regulation, as it is I will continue with code 3's and come new year c3 should suffice.
Thanks for all your help.
I agree about c3, the reason why I have been giving them code 3s is because unless u open up the wall and check you are unable to find out if they are i) more than 50mm deep, ii) mechanically protected, etc.... therefore requiring further investigation.
I didnt think it to be as serious as a code 2, but you may be right in some circumstances.
once again thanks man, I'm glad you decided to help, otherwise I would still be flicking through the pages of the holy book.
Reply to rcd or not to rcd, that is the question in the Australia area at ElectriciansForums.net
I will go over and get some photos, the CU is well labelled and very long with many breakers. I never seen one that big in a small flat but then I...
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
