Rcd protection for underfloor | on ElectriciansForums
Discuss Rcd protection for underfloor in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N6rul
Luton
Please can someone inform me what rated Rcd would be used for an underfloor heating in a bathroom?
Good luck to everyone holding the 2394 exam tomorrow.
underfloor heating
Ok, in a bathroom I was aware that a 30 mA RCD should be used, but was not sure If this applied to the underfloor heating, what if it was in a living room, would the rating of the RCD be different.
Re: underfloor heating
If it was in a living room, there would not be any requirement for RCD protection.
As such the rating would be up to you.
Reply to Rcd protection for underfloor in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I
Water underfloor heating and epoxy grouts Hello, I did some reading here and there, but the opinions seem to diverge at some point and I am not...
istefanov87
I
im just assuming that they are designed to be surrounded by material, and would heat to a certain amount, spreading the heat into the material...
