RCD Protection Question...... | on ElectriciansForums
Discuss RCD Protection Question...... in the DIY Electrical Advice area at ElectriciansForums.net
Pete E
N Wales
I live in a house built in the early 90's with the old colour code wiring. The MCB's in the CU are split over two RCD.
The socket outlets are all on one Ring Final circuit which covers upstairs and downstairs plus the integral garage.
I use one of the sockets in the garage as a supply for the electric lawn mower via a plain jane extension lead.
Last year, while cutting the grass while it was a little damp, I got a very slight "shock" (more a tingling sensation )...this did not trip the RCD ...The mower was on its last legs anyway, so I replaced it and all has been fine since. I also manually tested the RCD's in the garage and they tripped ok..
However, with grass cutting time getting closer, I am just wondering if any additional RCD protection would be wise? If so, would it be best to change the socket out let to a dedicated RCD one or get an RCD extension lead?
Our little grandson like to "help" in the garden, and I want things to be as safe as practically possible..
Having rcd's in series doesn't really hemp.
Tingling could be symptomatic of an earthing issue ......
Do you have any test kit?
When you say you tested the RCD you mean the ‘T’ button on the RCD? If so, it only tests it mechanically.
Probably best to get your place tested if you’re concerned!
Hi Pete - agree with @Murdoch having another RCD in series won't help. But you could get the existing RCDs properly tested (the test button push is a start, but not the end of testing). Just FYI, a current that causes the RCD to trip will more than tingle if it goes via your-good-self.
As Murdoch says. Its worth getting the rcd tested electrically and also get the earthing checked. A rcd will not operate correctly if the earthing is not adequate, since it measures an imbalance via "earth leakage" current.
That's what I was wondering or whether I could get an additional RCD with a lower trip current?
I think you are right about the earthing and if I am honest, the lawn mower and its lead were well past their sell by dates and I was just being a tight arse not replacing them earlier...The mower was replaced and the problem did not re occur and I've not had any other issues with that socket before or since.
Really my enquiry is "precautionary" ie is there anything I can do make things safer?
I doubt the earthing is an issue as I suspect the mower to be double insulated.
I should add I did check the socket with a plug in socket tester, then visually, and then double checked the earth continuity with a multi meter back to the house. I also (later) tripped the RCU with a borrowed tester which had that facility, and it worked fine...
99% sure the culprit was the poor condition of the lawn mower...
Most mowers don't have an earth connection
I think I was the earth connection at that point!
Would the resistance of long extension lead combined with mowers own lead cause any issue to prevent the RCD tripping if the current was only small?
I suspect this is the case of a damp electrical appliance and insufficient current to activate the rcd.
If I am honest, the whole set up/circumstances could have been a poster for "Not what to do..." and I think I was lucky only to get a tingle, but lesson learned!
Reply to RCD Protection Question...... in the DIY Electrical Advice area at ElectriciansForums.net
If the socket is installed in a safe place that's fine - you can't influence what people will plug in in the future.
I e got a guy coming out tomorrow to do some proper testing, it's just driving me insane 🤣 At the moment it's probably got no more than 2kw...
