P
piz
Hello again
I know this might sound stupid bit it aint if you dont know
I do some Electrical work for one of the national kitchen diy stores only just started and on my paper work it says
install RCD protection to existing ring main
ok I can obtain a rcd shower/garage unit with an rcd and 32amp mcb a henley block double pole and some 25mm tails break in to the main tails screw on my mini unit remove the ring from the old wylex board connect it to the new breaker and then it is protected not to forget the earth
is there any other way someone said it can be done with some 6mm cable but i was unsure what he meant
guess this is a long winded way any ideas or better ways would be great
Cheers
Cheers
