Discuss Rcd ramp testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
#Can someone tell me when and why would I need to do this test? Thanks in advace.
By doing a ramp test you see what current the RCD actually trips at.
i,ve often thought that with the price of rcd,s they should come with a calibration cert.
yours benji
It's a good weapon to use in the battle against accumulative leakage earth faults too.
If you suspect a particular appliance may be faulty then ramping the RCD with this appliance plugged in and switched on will show how much leakage it's already putting into the circuit as the tester will push out less current before the RCD trips.
Reply to Rcd ramp testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
