RCD Requirements | on ElectriciansForums
Discuss RCD Requirements in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hi All
Just a quick question, when did the regulation come in where RCDs are required for all cables buried less than 50mm from the surface?
If possible I need a date.
17th. 1st edition jan 1st. 2008. and it's not all cables<50mm. if other means of protection are installed. as per 522.6.101 (bgb. not got byb. might be a different reg.no. now.).
Reply to RCD Requirements in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
Ah, Eggborough. That brings back memories. Mainly happy apart from working on the 'valves board' and when they accidentaly almost fried one of the...
