RCD test button | on ElectriciansForums
Discuss RCD test button in the UK Electrical Forum area at ElectriciansForums.net
Michal
London
What was the reasons for changing intervals time between,from quarterly to every 6 months?.
think the idea might have been to test when the clocks were put back/forward as that saves resetting all the clocks just for the RCD tests.
nah, can't be. it's too sensible.
I think it was the "clocks change" argument for the 6-months label as you see different RCD saying monthly, quarterly, regularly, etc. I think the reality is they are tested when EICR are done and that is about it!
It is one of the reasons that I don't approve of ignoring the Zs or R1+R2 values and assuming the RCD side will cover their asses on any fault, the RCD should be for additional protection, not as the only means of disconnecting in under 0.4s because of poor design or degradation of the installation, since RCD electronics is more complex and they don't get tested in practice.
Because it's what the rest of the world does. As alluded to by @telectrix the ideal thing is to do it when the clocks change (as advised in many jurisdictions).
I take it from that you'd never install a TT system then? Is a TT system a poor design?
Reply to RCD test button in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
