Discuss RCD test button in the UK Electrical Forum area at ElectriciansForums.net
Not really as I believe it is just a mechanical feature of an RCD to test the mechanics of the device that it would operate in event of a fault and not 'stuck'!Hi, can anything else cause a RCD test button to fail, besides a faulty RCD.
NE fault on a load , if RCD is in circuit, so if test button fails, try disconnecting outgoing ccts from RCDHi, can anything else cause a RCD test button to fail, besides a faulty RCD.
Lack of earth.Hi, can anything else cause a RCD test button to fail, besides a faulty RCD.
Not on any RCD I can recall. Test button connects a resistor between one pole on the input side and one of the other poles on the output side, creating a 30mA or so difference (on a 30mA RCD) between whatever current is flowing through those two poles.Lack of earth.
you may well be correct but I have known some rcbo's to not trip when the flylead is disconnected.Not on any RCD I can recall. Test button connects a resistor between one pole on the input side and one of the other poles on the output side, creating a 30mA or so difference (on a 30mA RCD) between whatever current is flowing through those two poles.
No earth connection involved.
Reply to RCD test button in the UK Electrical Forum area at ElectriciansForums.net
