P
PB1
If an RCD passes the manual push button test, is this any indication that it will disconnect in the required time under actual fault conditions?
Discuss RCD test button in the Australia area at ElectriciansForums.net
yes and after doing the 6 tests for RCDs...that is x1/2..x1..and x5 and again at 180 always do the manual test by depressing the test button....if the RCD fails to operate 1st time by manual test then it should be condemned.....by the way.....failure to do the manual test after the 6 tests above when being assessed on the 2392 and 2391 will be marked against you......
What's the theory behind this Glennspark, I.e. why the test button last. I have been told this before but can't recall the answer and now its doing my head in!
Cheers,
Rob
its functional testing....What's the theory behind this Glennspark, I.e. why the test button last. I have been told this before but can't recall the answer and now its doing my head in!
Cheers,
Rob
Reply to RCD test button in the Australia area at ElectriciansForums.net
