Rcd test on sub main | Page 3 | on ElectriciansForums
Discuss Rcd test on sub main in the UK Electrical Forum area at ElectriciansForums.net
swaley
Essex
Hey guys do i need to do a full schedule of tests after installing a supply to garage with additional board.
Or do I only issue test results for the individual circuit i.e Garage.
I realise I would need a 2nd schedule of tests for the 2nd DB.
Also my 2nd DB has no RCD. So I presume I only document RCD when testing main DB on first schedule of results?? And not on 2nd DB in Results??
Hope this sounds clear??
Reply to Rcd test on sub main in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
