Rcd test | on ElectriciansForums
Discuss Rcd test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sparko
When doing the rcd test on sockets. Do you repeat the test at every socket in the ring or just at the middle of the ring, and within what time does the rcd have to trip at x1 its tripping current 200ms or 300ms? Thanks
doing the tests at roughly the middle socket is exceptable and the tripping times of rcds depends on the rating of that particular rcd ie 30mA IS 40ms
If you do the tests at the DB, it can be a lot easier and faster.
For a BS61009/61008, the 1X maximum trip time is 300mS.
For the older BS4293, the 1X maximum trip time is 200mS.
Both should have a max of 40mS on 5X
When doing the rcd test on sockets. Do you repeat the test at every socket in the ring or just at the middle of the ring, /QUOTE]
You are testing the charecteristic of the Rcd,this should be done on the load side with all loads disconnected
As advised,it is best tested at the consumer unit
You dont have to Rcd test at the sockets themselves,anywhere on the ring
It does'nt make any difference where in the circuit you do the test from, given the opperating speed of an RCD the closer to the rcd the easier it is to reset during the test cycle.
Yes but if the RCD is required work in real life the load will not be disconnected, so don't think that they are always going to react as your tester said they would.
I'm telling you the correct procedure for rcd testing as per IEE Guidance Note 3, not my opinion...
GN3 recommends to test between the the line conductor of the circuit and the cpc with the load disconnected.
This could be done at ANY socket and NOT the CU. You cannot have implemented safe isolation and test at the CU as the RCD test is a live test.
As is Ze and PFC....
Both carried out with the Main Switch in the OFF position
But still a live test!
How will you test trip times on a lighting circuit fed via rcbo, up at a luminaire or at the consumer unit?
It's all about competence!
Reply to Rcd test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
