RCD Testing 17th edition | on ElectriciansForums
Discuss RCD Testing 17th edition in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
South East Kent
Hello all,
when undertaking rcd test on 17th edition duel board do you have to test each individual circuit, or can you just test the two rcds. I have been testing each individual circuit but A collegue believes that you only have to do the later.
Any clarification would be greatly appreciated
Many Thanks
Hello all,
Many Thanks
The requirement is to test the RCD and this should be done at the RCD with no connected load.
The results are applicable to all circuits protected by the RCD.
Reply to RCD Testing 17th edition in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It can also mean lasts or continues for two years.
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
