RCD Testing | on ElectriciansForums
Discuss RCD Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
cosine
co durham some time
Hi All This Question came up in conversation today
Can you use a RCD rated at 230 V 30 ma to cover a 110 v 30ma circuit
Will it still trip in the recomended time
Thanks again
Thanks again
I don't think so.
Site transformers usually work on a phase to phase 110v if I remember rightly so you don't get L - N in the usual sense.
I would have thought they're not compatible.
I await correction
its normaly RCD protectiong the 230/400v side of transformer not the 110v side I have seen 110-230v transformer with RCD but the RCD was on the outgoing 230v side
Reply to RCD Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
